TwinTurbo.NET: Nissan 300ZX forum - PCV on underside of plenum near balance tube flange
madscientist222
on February 02, 2013 at 4:56 PM
using boost leak tester...still can't find leak!
posted by drew32
on February 02, 2013 at 04:43 PM
is all i can think of. How old is the valve/rubber?
drew32
16:43:53 02/02/13
PCV on underside of plenum near balance tube flange -
madscientist222
16:56:05 02/02/13
it is probably original with ˜80k on it
drew32
22:52:56 02/02/13
Sounds like the old rubber may be cracked/worn.
madscientist222
13:36:48 02/03/13
ok thanks all. I ordered new PCVs and hoses
drew32
14:57:52 02/03/13
^^ 2nd
SammybTT(TN)
22:54:34 02/02/13
I don't think boost should pass through to the hose
njz
08:00:00 02/03/13
right now i have a compressor hooked up to the intake
drew32
10:17:37 02/03/13
I talking when boosting not 5 PSI air. (n/m)
njz
17:21:20 02/03/13
Yes, I believe there should be
Summeronthechain (MN)
11:19:18 02/03/13
Boost shouldnt, but a boost leak test will pressurize both
madscientist222
13:38:10 02/03/13
Idle valve? (n/m)
JonnyZ(SoCal)
23:01:03 02/03/13
if you can feel it, you can find it . If you have big hands
Xteam300TT (South Tx )
23:23:07 02/03/13
i had trouble finding one on the back side of the motor...
BOOZT_JUNKIE
16:17:46 02/05/13
